Page 2 of 2
Re: More connectors!
Posted: Sun 18. Jul 2021 22:10:19
by AlexAusTelfs
Posted: Sun 18. Jul 2021 22:16:23
by AlexAusTelfs
just a hint: Even if your ESC has no BEC you still can use the port for powering the Spirit.
On my Jeti DS12 I can adjust everything. Only GPS is not available.
But as the Sys Port is easy accessible connecting my field pc is not a big deal.
As written I need a PC anyway to erase all the errors from my Spirit before flying.
Alex
Posted: Sun 18. Jul 2021 22:40:33
by minim
I know that. I have solved this by making my own harness powering all the servos external before the Spirit unit now. It would just be neat to have two more ports for a neat setup without using Y-splits. My setup above is pretty normal for a 800 size bird and it does lack a connector even if I remove the wifi.
If you had the wifi module then it would be a quick log delete before flight from your mobile phone or you could always connect with your pc without any cable fuzz. It's really neat to have it installed and always on.
