Page 2 of 2
Re: Spirit Settings 3.3.1 crashes on Macbook
Posted: Fri 09. Jul 2021 10:46:57
It seems problem was fixed.
Please retry with this app:
https://www.spirit-system.com/dl/settin ... r2-mac.dmg
Posted: Fri 09. Jul 2021 17:12:55
by JoergZ
i beg pardon but not yet for me.
i have append crash report. (deleted)
regards
Posted: Fri 09. Jul 2021 21:24:45
by HeliMLM
on all of mine {iMac 27 2013 Catalina, iMac 27 2017 Catalina, Air 2014 Catalina, Air M1 2020 Big Sur} this version is working, only on MacBook Air 2014 i had to restart once (really only once) after crash - this is the MacBook Air i had not installed the latest 2-3 versions on... it was still on 3.2.0 or so. all others working immediately after copying into 'programs'. all of them are now working...
nb: updated iMac 2017 and MacBook 2014 to Big Sur this evening... after installation of newest SiLabs (6.0.1) spirit settings (3.3.1.r2) worked immediately on both of them.
Posted: Fri 09. Jul 2021 22:02:37
by JoergZ
I also copied Spirit Settings 331r2 into the program directory, but restarting and resetting UBS ports does not matter - unfortunately it remains with the said crash. a pity
Update:
although I had installed the latest SILABS driver 6.01, I ran the driver installation again.
This has now actually led to success.
Many thanks for the support
Posted: Mon 12. Jul 2021 8:13:22
Thank you very much for the reports!
Re: [SOLVED] Spirit Settings 3.3.1 crashes on Macbook
Posted: Sat 17. Jul 2021 11:28:39
by onit12
Folks, how did you get the problem under control?
Brand new Mac mini M1 on Big Sur 11.4: Although I tried the "3.3.1.r2" and reinstalled the SiLabs (6.0.1) my Spirit Software is crashing when USB-Adapter is connected (without not). Starting extracted Software from "Programs".
Crashlog attached!
Tino
Posted: Fri 23. Jul 2021 0:15:33
by yufasa
Afraid this is still not fixed. I am able to run older versions no problem and actually updated one of my units to 3.2.2.
As soon as I open 3.3.1.r2 it crashes.
I then moved to my new Mac and same thing. Both are running Big Sur
Posted: Fri 23. Jul 2021 0:20:40
by yufasa
Okay so it appears to be the popup that tells you what is new that is causing the issue.
Once I restarted many times I ran through a demo, restarted the spirit and then tried again and this time the popup came up.
Not sure why that is but I have now updated one of my spirit2 units to the latest version...
Posted: Sat 31. Jul 2021 14:05:58
by onit12
Any news on this?
Perhaps the admin could change the topic to „NOT Solved“
Tino
