Spirit 3
senaka
would be nice to see a feature comparison between the GT and ver3. Looking at the specs its almost identical but the ver3 costs less? :roll: :?: :roll:
Comparison list can be found here:
https://spirit-system.com/features.php
Main difference is that Spirit 3 components are produced out of EU. This allowed to shrink costs significantly. In EU even raw electrical parts costs more than the very same parts sourced and assembled in Asia. All other products are fully manufactured in Czech Republic. You can decide what do you prefer more. Based on what people will prefer we will be releasing products.
ExCCHP
ZeXx86 wrote: Fri 02. Jan 2026 11:11:54 Comparison list can be found here:
Thank you for being open and transparent. So refreshing!!
With what is going on and been uncovered in the USA, I personally would be willing to spend the extra money to have the unit and it's components manufactured outside of Asia (presumably China).
But that's just me. To each their own.
Cheers
senaka
indeed, thanks for your transparent elaboration and the fact of passing the cost advantage back to your customers! well done to the Spirit team positioning the Spirit 3 in the current market..
Dieter Kunze 123
Beim Einrichten meines V3 funktioniert die Rettungsfunktion, aber wenn ich die automatische Rettungsfunktion auswähle, erhalte ich die Meldung, dass diese nur auf GT-Modellen usw. unterstützt wird.
Die Firmware ist auf dem neuesten Stand.
Habe update mehrfach gemacht ohne erfolg was muss ich machen?
Gruß Dieter
Dieter Kunze 123
Hallo
The rescue function works when I set up my V3, but when I select the automatic rescue function, I get a message saying it's only supported on GT models, etc.
The firmware is up to date. I've updated it several times without success. What do I need to do?
Regards, Dieter
it is important to update also PC software, not only firmware. Spirit 3 comes with the latest firmware so this is not needed to update, but PC software is likely outdated.
After using the latest version, it will work well.
