Issue with Coming Home function after updating to FW 4.03/4.04
Dr.Fleming
Hello Tomas, please find attached to this message the setup of my Spirit from my 580 Kraken, I have another Heli Kraken 700 with the same issue. Regards
- Attachments
- Kraken 580 after FW 4.03 Update coming home function not works 01062026.4ds
- (255 Bytes) Downloaded 191 times
Dr.Fleming
Looks that is not just adjust a little thing, I'm nearly from the begining here and if a user can fix it, believe me I already had fixed and not ask here for Help, it is a Software Bug form the new FW up FW4.
Dr.Fleming
Hello Tomas, can you please answer just to confirm that you receive that I send you 3 times the Setup File, thank you.
Dr.Fleming
Today test it with wind and Position Hold doesn't work , but now today the Coming home function works similar to a Position Hold function.
senaka wrote: Wed 10. Jun 2026 16:07:29 Have you tried position hold? Does it try to stay in one place?
"Coming home function works similar to a Position Hold function" you mean that it held the position at a random coordinate (not the home position) when you triggered return to home?
Are you sure the compass is calibrated / reclaibrated and the heading shown in the software is 90 degrees?
Backup your current settings (so that you can restore it later) and for now just test one function - Position hold. disable everything else. if it does not hold, this need to be addressed before moving to more advanced functions such as RTH return to home.
