[SOLVED] Bluetooth +app not saving changes
mattbeau
Yes on the galaxy tab running lollipop I can swipe right and press menu but nothing happens. If I press the three dots nothing happens
Sent from my Nexus 5X using Tapatalk
error414
we are working on resolve the issue.
Petr
Logo 600 3D -> Spirit FBL
Spirit settings Developer
mattbeau
Great! Glad to hear :)
Alyon187
Try switching banks (if your using them) and itll automatically ask you if you want to save changes.
Also, last time I tried to disconnect the bt without saving changes I heard an alarm go off and a notice pop up saying that there were unsaved changes.
velocity90
Alyon187 wrote:Try switching banks (if your using them) and itll automatically ask you if you want to save changes.
Can't use banks until we can use more channels. My 7th channel is switching power for the Bluetooth module. I need an 8th channel.
Ideally I would like to set gyro gain staticly so I have ch5 but that's not possible. I hope in the future.
mattbeau
I'm only using one bank. I guess I could make 2 duplicate banks and try saving that way.
FWIW my galaxy s7 runs fine with Marshmallow.
The galaxy tab s2 is supposed to be updated next month to Marshmallow. I assume it will work correctly then
Sent from my SM-G930V using Tapatalk
mattbeau
So I updated my galaxy tab s2 to MM and still not able to save.
I also tried a different launcher just in case.
Sent from my SM-T710 using Tapatalk
We have found that the issue is caused by custom firmware (non-stock Android).
But already found a possible solution which will be available soon.
velocity90
My nexus 9 and phones all have stock firmware
I have meant modified by the manufacturer to fit needs/device.
