[SOLVED] Bluetooth +app not saving changes
velocity90
Im i suppose to save the changes I make manually? If I disconnect it says changes are not saved.
It works in the same way as the PC software.
You should save settings to the unit if you want to store it permanently (not loose with a battery disconnection).
velocity90
Ok where can I find the save function?
In the context menu - there are many other functions as well. Just press the Menu button or "3 lines" icon.
velocity90
That explains, menu button not working on my nexus 9 tablet :(. (Android marshmallow)
It does on my phone(kitkat)
error414
you can tap to "three blue dots" on top-right on screen or you can slide from left to right and then tap to "menu"
check this
Logo 600 3D -> Spirit FBL
Spirit settings Developer
velocity90
I know, doesn't work on my nexus 9 (marshmallow) does on kitkat
Coco66
velocity90 wrote:I know, doesn't work on my nexus 9 (marshmallow) does on kitkat
Also sliding does not work?
velocity90
Sliding does work but the menu button does nothing
error414
hmm this is problem :( Do you use android from google or some custom ROM? It seem that I have to rewrite menu in android app.
