Geolink position hold problems.
rhmaddever
I had the same issues on my first flight. An increasing drift requiring more cyclic stick to correct and eventually i lost control.
If the unit is very sensitive to small vibrations I'm unsure ill be able to determine and correctly resolve them.
For example a tiny imbalance in the tail rotor will be very hard to fix?
I desperately want this to work!
Well, Spirit units are the most tolerant units out there. So if there is some issue caused by vibrations, they are pretty high.
Unfortunately with smaller models frequency/RPM increases so it might look like a small vibration.
Vibrations where you can see spikes along the plot are resonant and are the most problematic. They can be caused by things that are not holding well at the model. Even by connectors, nuts, cables. If they are produced just by motor, I would focus on these things around. Motor itself is looking good, because no high specific spike is visible. You can try to hold parts of the model and observe the plot while motor itself is running.
The most tolerant setting is:
Advanced/Stabi Correction OFF
Advanced/Signal procesing: Extended
Please note you can turn off Stabilisation or any function at any moment. So when you are in normal flight mode no drifting should happen. This mean if you will observe anything odd, it is enough to turn off the feature and continue in normal flight without any problem to prevent loss of control.
lkremenak
Dobrý den. Mám stejný problém. Pročetl jsem celé toto vlákno a řídil se radami které jsem zde našel. Po neúspěšných pokusech se zapnutým režimem držení pozice pomocí Geolinku jsem vždy v logu z letu našel hlášky "Přijatý rámec dat byl poškozen" a " ztraceno spojení s modulem geolink. Předělal jsem kpmplet geometrii rotorové hlavy a seřídil vrtulník tak, že v režimu stabilizace se vždy v bezvětří po puštění pák zastavil a téměř stál na místě. Vylétal jsem celou baterii, vše fungovalo v pořádku, v logu nebyly žádné chybové hlášky. Po zapnutí geolinku stále nefunkční držení polohy a stále v logu uvedené chyby. vyměnil jsem přijímač spektrum SRX2 za dva satelity DSMX, stále stejný výsledek a stejné chyby v logu. Postavil jsem vrtulník venku na stůl, počkal až nachytá družice, ponechal vrtulník zapnutý ale nespouštěl jsem motor. Chvíli jsem mixoval kniply vysílače, podíval jsem se do logu a tam stále hlášky "Přijatý rámec dat byl poškozen" a "ztraceno spojení s modulem geolink ". Nevím už co s tím.
Konrad
Position Hold works perfectly for me. However, I've had to fix issues with GeoLink twice by replacing the cable. It could be the cable or the delicate connectors. Maybe this tip will help—maybe not.
lkremenak
Děkuji, vyzkouším na jiném vrtulníku a s jiným kabelem.
