SRXL2 Technology
10x
Hello Tomas
Thanks for this, will try at the weekend...
10x
Hello Tomas
I see from the new software that there now is a srlx2 in the receiver section. If i have the spm4651t and 2 sats do i now pick srlx2 in the menu.
Before with the spm4649t i had to pick dsmx...
Regards Adrian...
SPM4649T does not support SRXL2 so everything is same here.
10x
Hello Tomas
I want to put in a SPM4651t with 2 dsmx sats. If i choose SRLX2 for the SPM4651T, will the 2 dmsx sats still work? this is on a Spirit Pro...
Regards Adrian
No, DSM2/X satellites and SRXL2 receiver will not work together. You have to get SRXL2 receiver and SRXL2 satellite.
10x
ZeXx86 wrote:No, DSM2/X satellites and SRXL2 receiver will not work together. You have to get SRXL2 receiver and SRXL2 satellite.
Thanks for this Tomas..As there are no SRXL2 sats available at the moment i will wait untill normal DSMX sats can be used...
Regards Adrian
tfmcnellist
The SRXL2 remote receiver (SAT) link below.
Available late March
No external antenna wires!
https://www.horizonhobby.com/dsmx-srxl2 ... er-spm9747
Will these 4wire sats use an adapter to work with the sat port or use an adapter to connect to the main connector pins?
These receivers can't be used with satellite ports. There will be adapter which will be connected at the AIL/RUD port.
This adapter will be available for sale likely this week in our eshop.
ragge1
Can the 4651T be compined with DSMX sat ? , as this is possible with brain2 and even the new Spektrum FBL unit
Skickat från min SM-G950F via Tapatalk
tfmcnellist
Will the sRLX2 receiver and SRLX2 satellites be connected to the same port through the Spektrum Multi adapter?
