SRXL2 Technology
ragge1
hi will Spirit support the new spektrum SRXL2 protocol
will this rx be compatible :
http://spektrumrc.com/Products/Default. ... D=SPM4651T
Yes, it will be compatible.
Torpicaltrail
The new SRXL2 Remote Serial Receiver with Telemetry (SPM4651T) looks interesting. However, Spektrum and Horizon have limited information.
How will it connect to Spirit? What cable(s) needed?
HH website lists "SRXL2 Remote Receiver Extension", available in several lengths on the product page below, but no pictures and no instructions.
https://www.horizonhobby.com/srxl2-remo ... y-spm4651t
TDNKKK
ZeXx86 wrote:Yes, it will be compatible.
SRXL2 remote receiver uses a 4-pin connector (not 3-pin). How are we going to connect it to the satellite ports on the Spirit 2?
It will be connected in the similar way as SPM4649T.
TDNKKK
ZeXx86 wrote:It will be connected in the similar way as SPM4649T.
Tomas, will you make multi adapter with 4-pin heads?
TDNKKK
So, it looks like the new SPM4651T also makes use of the NC port/wire. If we are told that it works the same way as the SOM4649T, then does that mean we should ignore the “NC” wire and connect the other three (Volt, Signal, GND) to the Jeti cable just like the spm4649? Please advise.
N/C mean Not Connect.
Yes, we will make adapter for the new receivers. So that it can be easily plugged to the unit.
Support will be included very soon.
RV1TD
Great, thanks! Will look forward to seeing an update in the manual
