Page 3 of 5
Re: Update Spirit Pro from 2.80 to 3.00
Posted: Tue 14. Apr 2020 17:38:23
by tomsl
Hello
my unit is straight and the LED opening/labels are at the top!!!
I pressed CTRL+ALT+U (this process was successful).
it is still exactly the same, when pressing the button Rescue the swashplate tilts forward ???????
So what shall I do ?
many thanks
Thomas
Posted: Tue 14. Apr 2020 17:57:24
Tomorrow we will check the settings.
If nothing wrong will be found, then the only thing that could be wrong is part of the sensor which was not possible to see with a previous firmwares. In that case we will replace you the unit.
Posted: Wed 15. Apr 2020 11:06:12
by Jo Decuyper
Hello
I reported on strange behavior from my spirit2. I also have a spirit pro. The difference is that the pro has 9-axis sensor fusion and the spirit2 has 12 axis sensor fusion. Could that affect the behavior? (apologies if this is a stupid question)
Second question. With your feedback I could confirm that the mounting of my spirit2 is correct and so are the settings. I am not a Wizz, so to be on the safe side I would like to roll back to FW 2.8.0. But it is no longer available on your website. Could you make it available again?
thanks for your help, much appreciated
Jo
Posted: Wed 15. Apr 2020 11:18:55
behavior on all units should be same, with Spirit 2 it should be just better. So with all units it should be significantly better than with old firmwares.
The mounting photo and settings can help us to find the problem. With current info we only know - it does not work properly.
Here you can find download links for old version, completely all versions are still available.
http://www.spirit-system.com/dl/fw/spirit-fw-2.8.0.4df
http://www.spirit-system.com/dl/setting ... -win32.exe
Posted: Wed 15. Apr 2020 11:29:59
by Jo Decuyper
thanks
I will provide some pictures of mounting and setup later today.
Jo
Posted: Wed 15. Apr 2020 14:29:18
by Jo Decuyper
Hi
I made a set of pictures of the mounting of the spirit2 and geolink as well as a ppt with pictures of the position of the swash plate under different settings. Hope this helps.
kind regards
Jo
Posted: Wed 15. Apr 2020 17:46:45
by tomsl
Hello
here is my installation situation TRex150
greetings
Thomas
Posted: Wed 15. Apr 2020 18:54:57
Thank you very much for all the details.
After communication we have found that units with inclined swashplate where even no accelerometer calibration has an effect, the sensor is partially bad.
The part of the sensor was not utilized by the previous firmwares, so the issue was not apparent.
Any unit with this error will be fixed for free by us.
The first indication that is showing there is something wrong is that swashplate is not level once rescue or stabilisation is engaged.
Posted: Wed 15. Apr 2020 19:10:17
by tomsl
Thank you, you guys are awesome!
Thomas
Posted: Wed 15. Apr 2020 19:28:26
We are preparing update which will automatically detect if sensor is faulty and inform pilot right after startup. In that way we can prevent any similar issue. Anyway there will be likely only few units like this.
Also our testing software will make sure no similar unit could be released, even that previously it was not an issue.
