uSpirit severe tail wag - motorized tail
daniel_i
@ZeXx86 can you help here please?
Hello, it should be at the P pin. With JST-Servo adapter it is middle pin, but without the adapter it is upper pin (pin where red wire is connected normally).
Manual was corrected.
daniel_i
ZeXx86 wrote:Hello, it should be at the P pin. With JST-Servo adapter it is middle pin, but without the adapter it is upper pin (pin where red wire is connected normally).
This is what I used, but I don’t get any RPM.
Is governor turned on or off?
daniel_i
Governor on.
daniel_i
ZeXx86 wrote:Is governor turned on or off?
This should make it clear
https://youtu.be/ujX-PHaEE6k
daniel_i
Hi @ZeXx86 any info on this? What else can I try?
we will try the same with our M2. It is only very busy time so at the moment we dont know what to do sooner..
I will let you know.
daniel_i
Hopefully you will deal with this issue soon because the unit looks promising.
I did some test flights and I can see some nice things with this unit.
Unfortunately without a governor, RPM drops too much.
I published a video to sum it up:
daniel_i
ZeXx86 wrote:Hello,
Hi, any update on this?
Can I help in any way? How can I make sure that I don`t have a faulty unit or there is no software problem in reading the RPM?
