spirit rs help
this is very correct behavior. It is described at this page in the manual:
https://manual.spirit-system.com/index. ... Stabi_mode
When you set Stabi/Function then depending on Function there is different Gyro mode - described all on linked page.
Gyro Gain between radio is different between menu in the radio and Spirit Settings because there is different multiplier.
Especially when you use Rudder Common Gain then the actual value in the radio has even smaller meaning. Important is always what you will see in the Diagnostic page. Same should be visible in the integration menu.
franz88
even if i I set up a channel separate to activate the rescue?
So if I disable the rescue (my stabi function) I can go to normal mode?
Yes, you are right.
Or you can set Stabilisation (Scale) if you want to use Stabilisation in Scale model with Gyro in Rate mode.
Or you can set another Bank with Function set to Disabled.
franz88
why the governor it does not set the rpm over 2500?
I increase the engine curve and all is ok until 2500 rpm over 2500 the engine doesn't go. (with max headspeed 3490)
If i changhe max headspeed the situation changhe max rpm 2300 (4000 max head speed)
I have
align rcm-bl520mx (dominator)
align rce bl75g (governor esc is deactivated)
sensor rpm hobbywing
162t main gear
145t autorotation
13t pinion
1:12.46:4.68
belt
I read the rpm on the radio
other people with trex 500 they fly with high curves also 100%
there is something limiting the power
Are you trying with Blades on or just on the bench with no blades?
The problem could be also in configuration of the throttle range. If it is not configured correctly then Spirit unit will reach this limit and RPM can't be higher.
Throttle range must be configured in the ESC with governor OFF with linear curve from 0 to 100%.
If it is not configured in the ESC then you have to adjust the range in Spriit unit manually.
franz88
yes the first time i set the esc with linear curves.
The governor spirt it was activated after.
I have set up many governors and helicopters.
I tell you how I think.
Or get to 1900usec and the governor goes no beyond. (throttle range max)
or is holding limit 80%. (this parameter I didn't quite understand what is it for)
I know the governor use max to 80% in this mode can increase engine if loses rpm but this model he needs of almost 2000usec
If you are testing on the bench then it might not work correctly.
You have to try with load - blades on.
It should work with default settings for Holding Limit.
franz88
I tested the helicopter in flight at 2500 rpm it's not good.
without governor this model with curve 85-100 fly well.
Holding limit I don't quite understand what it does.
Governor with parameters standard It has some engine curve limitations?
that I disable the governor and I tell you with which engine curve the model fly good ?
Other people with this model use curve motor 100-85-100 or 100 flat (is high but this model is in this mode).
Or i try to changhe 1900usec in 2000usec ?
franz88
I changed 1900usec in 200usec and holding limit from 80% to 95% and now the governor he arrives at 2800 rpm.
Now is ok.
But why if i active altitude limit of geolink the model goes up for a long time?
Every time I activate it goes high and I disable it to make it stop.
i use on1
Thank you for the message.
This unfortunately mean that the ESC calibration was not matching with Spirit throttle range.
Maybe the ESC was calibration with JETI receiver previously.
If Altitude Limit does not stop it mean there is some other function active, very likely Rescue mode.
It is needed to change settings.
You can send your settings file and I can check it.
