Spirit 2 with SRXL2 and DSMX sats
ianboom
Any more news on the update?
We are still preparing it and doing last tests. Thank you for your patience.
flo
Hi
not sure this topic was already replied somwhere else.
I have two SRXL2 Receivers connected to the spirit. One to the normal port and the second to Sat2.
I have problems that my DX9 sometimes says that ther is no telemetry data from the ESC.
According to this threat this should be fixed?
(But i miss the final OK from the DEVs)
there was never any issue with missing ESC telemetry but random telemetry and integration losses.
It is only needed that wiring and settings are OK if you are getting this problem.
Make sure that GeoLink support is disabled, otherwise SAT2 port is unused.
flo
sorry for the late reply.
Just tested it again these days.
Sometimes i see no telemtrie data or update on my dx9. The antenna Symbol is blinking or getting off on the display.
When i disconnect my receiver from the sat2 port telemetrie looks stable.
Control failover between the two receivers works fine. It´s just the telemtrie which sometimes stops.
best regards
Florian
