Page 4 of 4
Re: Loss of signal
Posted: Sun 17. Apr 2016 16:50:16
by stratos7
I have had loss of control twice with that wiring configuration, took the advice and not wiring like that again.
Re: Loss of signal
Posted: Mon 18. Apr 2016 7:33:21
If it was a bad cable connection and it is holding well now, it shouldn't happen again.
Static issue can be possibly simulated even without blades by changing throttle.
If you can start the motor and it is working without any strange behavior (no events in the log about lost signal) then it can be good as well.
Especially if the belt is more tight, it should be improved too.
Re: Loss of signal
Posted: Mon 18. Apr 2016 17:25:25
by stratos7
Thank you SIR for all your help.
