Page 4 of 5
Re: Bankswitch via jeti TX not working after setup changes..
Posted: Tue 24. May 2016 9:29:38
by Gtamas
And we can continue to use the "old" 2.0.1 Jeti BIN file? Or there will be a new 2.0.2 version of that?
Posted: Tue 24. May 2016 9:31:16
Yes, the firmware was designed so the update is not needed yet.
Soon there will be update of the Jeti file that will bring just a new features, but now it is not needed to fix the problem.
Posted: Tue 24. May 2016 9:33:44
by Gtamas
Thomas!
Thank you for your flawless support! :) Best support i met ever !
Posted: Tue 24. May 2016 9:50:12
by buell47
Gtamas wrote:Thomas!
+1 [emoji106] [emoji106] [emoji106] [emoji106] [emoji106] [emoji106] [emoji106] [emoji106] [emoji106]
Posted: Tue 24. May 2016 10:06:45
by Lars
Perfect. Thanks a lot!!
Posted: Tue 24. May 2016 11:35:59
by Thorvald
Thanks Tomas, will try it tonight.
Posted: Wed 01. Jun 2016 3:16:51
by mkleist
ZeXx86 wrote:Please download and flash this firmware:
http://spirit-system.com/dl/fw/spirit-fw-2.0.2-ex.4df
Finally the problem should be solved with REX receivers, we have found the problem.
Also the communication should be little bit faster now.
Response was different in a specific situations, now all should be good.
I recommend this firmware for all REX users, but it affects just the integration.
Would this firmware be ok to use without a REX receiver? I'm just about to setup my first Spirit Pro with a Jeti. Using a R3-RSW receiver for now.
Posted: Fri 03. Jun 2016 18:28:11
Yes, you can use this firmware. But for EX receivers it is not needed.
Posted: Fri 03. Jun 2016 21:02:07
by mkleist
ZeXx86 wrote:Yes, you can use this firmware. But for EX receivers it is not needed.
Awesome, thank you.
Posted: Mon 06. Jun 2016 18:07:23
by buell47
Hi Tomas,
after destroying and rebuilding my Goblin 700C I have tested your Firmware 2.0.2-ex with my Jeti and all seems perfect now.
Many Thanks again for your fast response and fixing.
Best Regards,
Frank
