Update 3.2.2
buttles
Ok, this got me wondering and I have just checked. The Servo menu is missing whatever I do!! The screens don't revert to previous page though......DS24 and RS
For me DS12 and RS everything is OK.
Maybe different versions of FW on the radio ...
http://www.jetimodel.com/en/Downloads/D ... sion-5-03/
I have in DS12 FW 5.05 (the new version fw 5.05 is only available in SW Jeti Studio 1.1.3).
HeliMLM
Klaus wrote:I also have some troubles with the Jeti integration in 3.2.2.
When I enter the Device Manager in my DS12 (FW5.03) ...
... so why don't you just bring your DS-12 to recent firmware? same here: 2 x DS-12 with up-to-date firmware, 6 Spirits (2&RS), integration working flawless!
cheers
Michael
buttles
Checked a DS16 (5.03) and a DS24 (5.05) against the same RS and both missing the Servo page. The DS24 with a red Spirit was the same.
A minor problem.......but? (It's cold and wet and in Lockdown so nawt else to do!)
HeliMLM
is it possible you are not in BANK 0? the integration menu is showing Servo page only in Bank 0, not in 1 or 2 (which is clear) ;)
cheers
Michael
buttles
:roll: Thank you Sir, yes I had the Bank switch in 1. Got caught out with the new F/W that doesn't go to bank 0 at startup.
Nothing to report here then, all good. :)
Klaus
Updated my TX to 5.05 - same Problems.
Returned my Spirit -RS unit back to 3.2.1 and also the Jeti Integration Files and everything works well.
HeliMLM
@buttles: great it‘s working for u now… ask me why i knew? :P
@Klaus: which bank?
cheers
Michael
Klaus
No bank switch assigned, bank 0.
It should be enough to revent BIN file, firmware can be latest, because the latest BIN file is requesting data much often.
Which, for unknown reason, is causing the troubles in your case.
We will be testing with DS16 soon on multiple RS units.
