Tested following:
New firmware 3.2.2 and old bin file -> same problems.
Then I again installed new Jeti integration files -> same problems.
At last I assigned a bank switch in my Radio and everything in Jeti Integration works well now.
I think new firmware 3.2.2 needs to assign a bank switch, otherwise Jeti Integration works strange.
Regards, Klaus
Update 3.2.2
We have tested with DS16 and latest firmware, Banks assigned and Banks unassigned.
Result is, it is working just perfectly in our case with all latest files.
Firmware 5.05 is working also well with DS12.
For this reason we would like to get your Spirit Settings file and we will load it to our units and retry.
We have tested also with Manfred's settings file and again, everything is OK.
Do you think it would be possible to disconnect everything from the unit, except BEC and retry?
I also tried to disconnect the telemetry sensor (Kontronik Kolibri) but that makes no difference.
Attached the old 4ds file.
In this setting also no channel is assigned for bank in the RS-unit.
Also I could not see the headline like Bank 0, Bank 1, Bank 2 in the Jeti Integration menue.
In my new configuration with assigned bank switch and bank channel mapping everything works perfect.
So no problem for me anymore.
Klaus
Klaus
- Attachments
- 2020_12_06_Voodoo600.4ds
- (255 Bytes) Downloaded 132 times
Could you please try to update to 3.2.2-r2 firmware version? It is available in the Spirit Settings from now.
I hope this can help you.
Oh, perfect. So now everything is resolved?
