All Controls Suddenly Gone!
Phil S.
Wiring is YGE original with thinner signal cables (that you see from above) cut to minimum length. Power cables are double 0.35qmm. It's this (PowerBox?) aircraft grade stuff with thinner isolation. In all (Jeti) logs, RC power supply looks absolutely healthy.
What do you mean with "uneven endpoints"? At 0° tail pitch, all links are at 90° and maximum pitch is as on most helis not symmetrical.
Tail control is perfect even at 1000/min headspeed, oscillations can neither be seen nor heard. Setup took me a while and even AI-Assistant is satisfied.
No logs from the event available. As written above it was not that easy to get the Spirit logging running.
Regards Philipp
