[SOLVED] srxl2 AR6610T
chris_0815
SRXL2 is definitely the future in the Spektrum world, they really push it.
Reading the SRXL2 documentation immediately reveals, that it is very powerful.
Based on their reference implementation, they make it very easy for 3rd party products to implement the SRXL2 protocol (example_app).
I still see no reason, why a FBL controller should not talk itself to two SRXL2 remotes. And they are IMHO very well capable of running directly on the Servo bus.
E.g. Spektrum's new FBL FC6250HX uses only remotes, whether they are SRXL2 or the older ones, i.e. even mixed mode is supported: see here on helifreak.
chris
latjo-k
10x wrote:Hello Tomas and all
Just to let you know that the problems is solved, The wire from spirit should be in port 1. This does not matter if you are not using a sat(4651t), but if you are you can only have connection in either SRXL2 port (4pin) or SRXL2 port(3pin) not both. By putting spirit wire in port 1 everything works ok with or without a 4651t.... :D :D :D
https://www.rcgroups.com/forums/showpos ... tcount=466
Hello
I have moved the connector to channel 1 on the AR6610T,and Everything works normal.
Thankyou
10x
latjo-k wrote: Hello
Thankyou
Well done on that....Another thing i have noticed with the SRXL2 is the problem with the telementry / integration not starting up first time has gone away... :D :D :D
http://spirit-system.com/phpBB3/viewtop ... =20&t=3300
latjo-k
Thankyou
http://spirit-system.com/phpBB3/viewtop ... ration+dx9
I never notis any problem whith that,not whith spm4649t or ar6610t.
10x
Hello Tomas
Thanks for the new firmware :D :D Did you get a chance to read this thread regarding wiring when you use 4651t as a sat with the 6610t?....
Regards Adrian
Joker
can someone pls tell me how to update the AR6610T.
Thank you in advance.
10x
Have you registered the 6610t on your Spektrum account? you will need a SPMA3065 lead and use the Spektrum programmer. If so you will be given the update firmware that is specific to your receivers serial number. It will then upgrade the 6610t to version 2.34.3. This is a new version from 17/4/20....
http://spektrumrc.cachefly.net/apps/spe ... ammer.html
Joker
thankyou, i have the SPMA3065 programmer cable and the spektrum programmer app.
I connect the AR6610T with the usb cable.
in the top right corner is writen: Cable and divice are connected.
But on the left site the button for softwareupdate is grey and i cant klick on the button.
10x
Joker
i have tried to registered my receiver first. But that doesn't work either.
So i asked spektrum for help and the send my this answer:
You will need the SPMA3065 PC programming cable and online PC Spektrum program application.
Cable and software can be found here.
Sign into your spektrumrc.com account from the Program and connect the receiver to the Programming Cable. The PC application will display the serial number and allow you to register and update the firmware directly within the application.
the last part doesn't work for me
