[SOLVED] Governor settings for GAUI NX4
SlezY83
Thank you for the info.
I know that it does not play role if there is used Satellite or AR7700, but I had problems with wiring of all cables when I used satellites (double power, glow module, telemetry, power connector for BT module... - I had to use about 3 or 4 Y cables - I do not like it).
On AR7700, I can use the connectors in the receiver instead of Y cables and in case of not possibility to use governor in Spirit, there are outputs for classic governor, but I hope it will not be necessary.
Would be possible to know when cca the FW update will be available :-)?
FrankFuss
ZeXx86 wrote:In the upcoming firmware there will be major governor improvements. Personally I can't be more happy so it can be worth to wait.
I have been patently waiting for good reports on the Spirit governor on nitro/gas helis, and will give it a try when you are happy with the results. I have a Goblin 700 gas heli and currently use a Stator Gator for RPM and a Futaba GY701 governor with somewhat acceptable results. I only wish that I could get Jeti/Spirit RPM telemetry when not using the Spirit governor so that I could compare the two governor setups.
It might be available in two weeks.
thestructured
Very excited to hear about more governor improvements :D
Thanks for the continued support and improvements.
