Rescue - pitch goes to zero and no attitude correction
this is good news !
Great Tomas could help you !
We never give up :)
A realy rare situation but now solved -
I wish you relaxed flights with your helicopter without any bad thoughts about the rescue -
Best regards
We can add it to the log, however this error should not happen normally and it is the first case that resulted in such behavior we know about within all Spirit units we ever produced.
If you are affected then rescue and all stabilisation modes will not work at all.
So you really do not have to worry your unit could have similar problem, otherwise it would end up in similar condition.
franz88
I'm happy you solved it
I understand that it is the first case and now if tomorrow it happens to another person in log exit error sensor and you understand in one seconds where is the problem.
When I used another fbl when the unit was turned on and swashplate jumps they weren't the exact number they told us to give a tap on the flybarless unit because they were enchanted the sensor.
Zexx86 you are SINGLE FLYBARLESS UNIT WITH AUTOMATIC RESCUE no one succeeded only you succeeded to get automatic rescue working.
COMPLIMENTS I assure you that this function only this function it is used to take spirit.
why saves the model
rescue normal if you don't make it in time to push button does not save the model
but rescue automatic always save the model
I see on my radio and in the logs the height helicopter and it's really accurate.
Tapping to the sensor is "required" if sensor is actually not in good condition and should be replaced because sooner or later it will happen again.
Sensors that are working properly will never do this.
In any case we added the event to the log now so you will be able to see such problem in the log in new update.
franz88
when i turn on the spirit if everything is ok how many jumps must do the swashplate?
for example 2 jumps if all goes well.
if there is any problem there are 5 jumps.
I never understood how many jumps he has to do if everything is ok.
I think it's a nice way to see if everything is ok.
franz88 wrote:when i turn on the spirit if everything is ok how many jumps must do the swashplate?
It is described in the manual here:
https://manual.spirit-system.com/index. ... _Solutions
When there is error in the log you will see elevator servo not moving same as other two servos.
When there is no important error then all servos are moving together.
When there is Rescue turned On during initialization then Swashplate will jump for 5 times.
franz88
you know I've never seen that page.
Why I go to the spirit rs and gtr page.
and in that page there are not here problems and solutions.
https://manual.spirit-system.com/index. ... piritRS/it
anyway now i understand.
I need to see the elevator servo.
If it doesn't move I have a problem.
