Re: How to power the red fbl system
Posted: Wed 04. Nov 2015 21:24:16
you can connect secondary satellite to the RUD port only.
Throttle must be connected to the AUX.
If you will use Y-harness, you can connect battery to the RUD (second free Y-harness cable).
In this way, it will work without any problem.
If you will need second power input, you can also use second Y-harness in the AUX.
If you are using classic receiver connection, then there are two power leads so you are feeding the unit from receiver.
