Dx8 rescue setup
Im a new spirit owner (regular red casing) and will be installing this on my goblin 380 build that ill be starting shortly. I would like to setup the rescue on my gear switch if possible (outside lower left switch). That way I dont have to take apart the radio to switch the bind and gear switch or not be able to use the original hold switch. I have my hold and flight modes on theie normal positions. Is there a way that I can get this set up?
You'll get the idea here:
http://www.helifreak.com/showthread.php?t=718597
As I wrote, go to that link and get the idea.
Then use it for whatever switch you like.
Just like Alyon187 stated, I too cannot figure out how to use the gear switch to activate the bailout/rescue function. When you go into switch assignment, there isn't an option to assign anything to the gear switch. I want to keep the trainer/bind button as it is because I use it for a flight timer. I was able to get the gyro function to work with the Aux3 knob. But, if there is a way to make this work with the 'Gear' switch, I am not seeing it. Anyone? Perhaps someone has another idea?
