Seperate sliders for collective
Posted: Sat 21. Nov 2015 16:00:33
by Alyon187
I think that having seperate sliders for setting max pitch and negative pitch would be great. This allows for us to set both sides to the same value. I havent set my unit up yet but have gone through the software a few times so if this is already possible and I didnt see it then im sorry and please just ignore this suggestion but if not then maybe this could be implemented on a further firmware update.
Re: Seperate sliders for collective
Posted: Sat 21. Nov 2015 16:05:19
There is no separate slider for collective, because it should be already equal if previous settings are done precisely.
In 95% cases it can be perfectly precise, but in some helicopers geometry is not symmetric.
In this case you can use Servo Travel Correction where you can fix the differences even for each servo separately. But it should be used only as the last option, because assymetry means that something is wrong. (mostly the problem is caused by inproper Subtrim settings)
Posted: Tue 09. May 2017 21:49:03
by curmudgeon
The only FBL unit I've seen that has separate sliders for positive and negative collective is the Neo. Every FBL unit has a unique method of evening the collective. The old VBar used to do it using the transmitter pitch channel travel. The Skookum units do it pretty much the same way as Spirit. I think I prefer the slider method, but the current system works.
Posted: Sun 14. May 2017 19:37:43
by velocity90
Totally missed this feature today setting up a new heli. Definitely something that should at least be mentioned while using the wizzard. A checkbox to move all 3 servo endpoints equally would be a nice feature.
Verstuurd vanaf mijn U FEEL PRIME met Tapatalk
