Firmware Download Problem
Heliman550
Hi there, I just bought a Spirit Pro and am going through the setup. However, I'm stuck as the Spirit Software isn't the latest version. I downloaded v1.3.2 and it's sitting in my "Downloads" folder but the software doesn't see it. I'm asked to select an application to open the file but Spirit doesn't appear as an option.
Next step is what?
Regards,
Heliman550
Coco66
You need to also use the 1.3.2 PC software, it will then see the 1.3.2 firmware (versions should correspond).
In few words:
a) install this software in your PC
http://www.spirit-system.com/dl/setting ... -win32.exe
b) power on the Spirit and connect it to the PC and run the PC software
c) use the PC software to upgrade the Spirit firmware to this one:
http://www.spirit-system.com/dl/fw/spirit-fw-1.3.2.4df
Heliman550
Coco66 wrote:You need to also use the 1.3.2 PC software, it will then see the 1.3.2 firmware (versions should correspond).
In few words:
Thanks for response. Already did this but now v1.3.2 is shown but doesn't open and won't uninstall either. Maybe it's a Windows10 issue?
Regards,
Heliman550
You can try to disable your antivir or other protecting software, it could block it for unknown reason.
