Log data
Alyon187
Quick question. Does the log only save the flight that there was a problem w? Andare all the warnings that will cause the unit to save the log and cause the nodd then pump of the swash?
I know if you have receiever signal loss and low voltage but if tou have high vibrations would it cause the unit to save that flights log as well?
yes, log is saved to the flash memory only in case, when there is something important you should really know.
Vibration Events are not that important, so these events are not saved. So when the battery is disconnected, you will not see it.
