set up with 5 servos
mb-1953
I am trying to set up a new Velos with the spirit pro. I set the swash type to 4 servos, 90 degree in the DX-9 Transmitter.
The spirit sees the throttle and rudder ok, but the pitch only goes from -60 to 60 and the elevator and aileron go from -120 to zero. I tried to set the mixing in the wizard for ccpm 90 degrees in the general tab but it doesn't change the readings in the diagnostic tab. I am lost.
mb-1953
I changed the transmitter to 1 servo normal and the transmitter matches the diagnostic tab. I dont know which servo is ch0, ch1, ch2 or ch3? Looking at the front of the heli from the back can anyone tell me how to connect them ?
They are at 12 oclock, 3 oclock, 6 oclock and 9 oclock.
what you can see in the Diagnostic tab is affected only by the transmitter settings.
In the transmitter you have to disable mixing, so each channel correspond to the stick movement.
It should work fine with default settings in the unit.
So a proper movement in the diagnostic tab is required (directions are not important there).
You should achieve -100 to 100% movement. I highly recommend to start with clear profile in the transmitter.
Then when it will be configured we can go for servo settings.
