Crius Bluetooth
omarb
Hi All,
Am new to the spirit system, just got my first one the other day. Still need to take it out of the box and was wondering if I can get the below bluetooth module to work with it? Any help will be appreciated.
Thanks in Advance
http://www.goblinhobbies.co.za/flybarle ... ter-s.html
CRIUS MWC Multiwii Blutooth Module Patameter Configurator Module/Adapter s
Coco66
I read here
http://www.helifreak.com/showthread.php?t=613675
that it can be used with iKon/Brain, so I suppose it's a viable thing, after reorganizing the wires in two plugs.
But only if it's also possible to configure Baudrate to 57600 (not sure about this).
This module can be reprogrammed and used without any problem.
So after setting up baud rate to 57600 it will work.
But it can be burned with higher voltages, so it is only for max. 6V.
omarb
Thanks guys for the help thus far. Can u tell me how would I go about wiring it? And how would I set the baud rate? From the spirit of from the pc?
Coco66
Search Helifreak for that...
Adrian
I once did it by AT Commands, on Crossover with 2nd wired USB Serial Module.
Entering AT Commands in Terminal Program connected to the COM of the USB Module.
AT+BAUD<index> 7:57600
Command would be: AT+BAUD7
There are different guides in the web like coco66 said: like with Arduino
http://blog.oscarliang.net/multiwii-blu ... baud-rate/
You will spend some time, but feel like a hero once it works.
I personally would buy HV BT Module direct from Spirit or its dealers for only 16Euros.
omarb
Thanks for that. I would have bought it, but in South Africa there is only one hobby shop I know that stocks spirit and they closed for the festive holidays. There service is A+ they made sure I got my spirit before they closed only I didn't think of the BT module than. Oh well will give the programming thing a go.
