Gyrocopter Application
Wonko the Sane
I would like to know if I can apply the Spirit Pro for Gyrocopter application? Head has elevator and Aileron settings only..
Andre
Could you post the model name or link for the Gyrocopter, please? Then I can answer your question.
Thank you very much!
kramrle
Hi Andre,
Gyrocopters or Autogyros are basically stable flying machines versus helicopters which are rather unstable by design.
For curiosity, how would you use the spirit in the Gyro?
Cheers Martin
Gesendet von meinem SM-G900F mit Tapatalk
Wonko the Sane
Hi Martin
The gyrocopter (Calidus 50E) has aileron and elevator on the rotating head, which in the normal way is controlled with mixing in a fixed wing set-up. I want to experiment with the rudder, and aileron/elevator setup in either 90 deg or 120 deg swash configuration. Should be interesting...
BR
Andre
Wonko the Sane
ZeXx86 wrote:Could you post the model name or link for the Gyrocopter, please? Then I can answer your question.
aerodragon Calidus 50E
Andre
