Disabled throttle settings
Alyon187
I just saw this in one of the older firmware updates where it says that throttle settings can be changed even with the gov disabled. Do I need to configure the throttle/gov settings tab even though im using the hw esc gov?
If your ESC is connected to the unit (nor a receiver), then it may be necessary to configure throttle range. But if it is working correctly now, there is nothing else you will need to configure in the unit.
Dark-Lord
To this end, I have a problem.
Kontronik (Jive Pro and Kosmik) should be taught with gas 0-100. This value is unfortunately too high for the Spirit. It maximized at 109% which about 83% are in the Jeti.
By Teach 0-100 has with the gas value (in the Jeti) also equal to the percentage of the maximum speed. One does not have this so test only
A change in the way the Governor-menu -50 - +150 unfortunately brings nothing.
Can that possibly be adapted?
I recommend to move in the opposite direction for Throttle Range - Min.
So for example your ESC could recognize throttle signal at around -115%
You can start the helicopter and slowly decrease the value until ESC will beep classic sequence.
