wiring of the spirit pro
Neilholt
Hi guys I have just ordered the Spirit pro it says it has 3 points of power in to the unit , I am running HV servos, and 2 spektrum sat receivers I have made a loom up to connect the power so I will connect one to the BEC (rud) and the other one to BEC (aux2), I also wanted to use optipower ultra 430 so need to attach the power from this to the spirit pro , so where does this power lead go to :?:
Hi!
You can use CH0 port which is mostly unused.
Neilholt
Hi Thank you that was a fast reply so just plug the optipower in to Ch0 :D
Yes, you are welcome!
