another mounting question
Neilholt
Hi Guys just a quick question when mounting the spirit pro it says vertical and vertical (top) is there any difference ,mine is mounted vertical with the wires at the front
in your case you should select "Vertical". Then everything will be OK.
Neilholt
Thank you so is vertical top mean wires at top of spirirt
Yes, exactly. With Vertical (Top) wires can be also at the bottom.
