Cannot Read Log Files (solved)
dogbreath
Cannot view log files.
Windows 10, Adobe Acrobat Reader DC, *.pdf files set to default to AcroRead DC, but log file tries to open and says no .pdf reader found.
Any suggestions? thanks, Dan
Synergy 516, 556 stretch, 696.
Coco66
Do you still have the "My Documents" folder?
If you accidentally deleted it, it will not work.
dogbreath
I still have the MY DOCUMENTS folder. It's not on the "C" drive, though. Does that matter? Does the Spirit write the log somewhere in the laptop?
thanks, Dan
Yes, it must be on the C drive,
elfew
Maybe better to have a dialog window with save location
DX9 - Chase 360 - Spirit
dogbreath
Added a new "My Documents" folder under the "username/Documents" library, but Spirit doesn't find it. Can someone give me the correct path for the My Documents folder so I can put it in the right place? thanks, Dan
Coco66
On Windows 7 the needed folder is
C:\Users\yourusername\Documents
elfew
Would be better to implement different mechanism how to save pdf logs
Adrian
same on WIN10:
C:\Users\[user]\Documents
+1 for save / open dialog
dogbreath
Here's where I created the My Documents folder, but I still cannot save logs:
C:\Users\Daniel\Documents\My Documents
Will have to wait for a dialog box, I guess. My system C drive is a smaller solid state drive, so documents have to go to a large spinning hard drive D:
Dan
