How do i make the heli stop harder.
nzflyer
Hi.
I want to make the heli stop harder from negative to postive pitch etc. do i increase cyclic feed foward. Also can i put some pitch boost in.
Sent from my iPad using Tapatalk
Cyclic Feed Forward is not affecting collective pitch behavior. This is affected by the main blades and your Collective Pitch range.
It should be equal for both sides if your collective pitch range is equal for negative and positive side.
Yes, you can use Pitch Pump booster parameter that is in the Expert settings. But mostly pilots are just increasing range or head speed to achieve faster response.
