RPM Sensor output question
Rcpassa
Hey guys, I have a quick question. I am currently running a spirit with a JEti ds 14 and a hobbywing 100a platinum v3 esc. I've always used the spirit governor and have now decided to use the hobbywing governor. I still have the hobbywing connected the same way with respect to the RPM Sensor but after disabling the spirit governor, the RPM output telemetry information is no longer carrying over to the Jeti. Is there a way to still get this data without using the spirit governor?
Unfortunately this is not possible, because Governor is processing RPM from sensor, so disabling it will disable also telemetry data.
Rcpassa
Is it possible to make that part of the next update?
Yes, but there are some issues that must be solved.
FrankFuss
Rcpassa wrote:Is it possible to make that part of the next update?
That would be great. I would like to switch to the Spirit governor eventually, and comparing the Spirit governor performace to the ESC governor using the Spirit RPM data would be useful.
Rcpassa
Tomas did an excellent job with the spirit governor. It certainly is excellent.
FrankFuss
Rcpassa wrote:Tomas did an excellent job with the spirit governor. It certainly is excellent.
Yes, that is what I am hearing, but I would like to be able to use the Spirit RPM telemetery in order to compare the Spirit governor performance to the also excellent Hobbywing ESC governor that I am currently using.
Rcpassa
Me too!
