[solved] BT App & FW 2.0.0
Posted: Tue 23. Feb 2016 20:05:45
by ajadda
Hi all,
did anybody connect successfully via Bluetooth with the new version 2.0.0?
I can not connect anymore since the mobile settings app was updated.
Trying to connect gives to following:
The apps shows a window saying:
reading data. Please wait
During that time the BT-LED gets solid blue and the app states "connected" in the background.
After a short while the app disconnects, the LED is blinking again, the app shows a window:
Spirit Unit not found
The old app for Version 1.3.2 was able to connect but stated some other error message, the data did not match, I guess.
I tested it with Android 4.4 and 5.1
Best regards,
Alexander
Re: BT App & FW 2.0.0
Posted: Tue 23. Feb 2016 20:25:49
by Coco66
Stupid question... do you have both the new App and the 2.0.0 firmware installed on the unit? (sounds like you do, but just to be sure)
Posted: Tue 23. Feb 2016 20:36:51
by ajadda
Yes, I updated the unit first via USB, corrected the requested changes, saved and reloaded the unit. Then I updated the app on the Android 5.1 System, but had the problems as described. On the Android 4.4 System I first tried the old app, the BT-connection could be esfablished, but no communication. Then I updated the app here as well, with the same result.
Posted: Tue 23. Feb 2016 20:49:09
by Coco66
Sure you connected the SYS plug correctly?
That's what would happen if you didn't...just tried it (with the correct connection my newer App and Spirit 2.0.0 connect perfectly).
Posted: Tue 23. Feb 2016 21:24:59
by ajadda
Coco, are you a clairvoyant?!? ;)
You were right, I double checked the connection and reinserted the BT-plug to be sure - now it works...
So the connection must have been faulty.
Many thanks,
Alexander
