Hi
I'm curious who has already updated to 2.0 and given it a shot. Is there any flight characteristic improvements over the 1.3.2 version that you can notice?
Thanks!
Who is flying 2.0 - any flight characteristic improvements?
I'm very impressed, my SOXOS 600 and SOXSO 700 just fly great with default setup, I'll give a try on my TRex450pro this weekend.
Cyclic feels very natural and precise, on TIC-TOC tail holds solid, without any tuning so fare. On rescue, the bird also climes straight into the sky, where with 1.3. it was sometimes a bit tilted to the side after a few unintended maneuvers. Just follow the wizard setup and you gonna enjoy. All I had to do was reducing Gyro Gain from 55% to 50%.
But what I like the most, is the Governor and its setup. RPM just holds great on my electric 6S and 12S Setups. It's now very easy to get ESC to work with Spirit Governor, even AutoRotation bailout works now as expected. Also Failsafe allows now to be programmed specific based on TX out. With 12% Throttle, ESC slow Spoolup after RF recovery will be avoided.
Big thx to the Dev. Team
I did test Trex450 and same results, it‘s just great with FW 2.0. All I had to do was lowering Gyro gain by 10 points.
And I did add RevoMix, as I got slow Tail Servo, but I had this with 1.3.2 as well.
