Bailout Question
Rcpassa
Hey guys, any idea would help with this new problem. I have an oxy3 Qube (3 head blade) and after upgrading to the latest firmware (I did everything as instructed- no problems - great setup by the way) when I activate the bailout, it always ends up with the nose pointing up a few degrees. Just enough to make the heli backup start in backward flight. Any ideas???
Alyon187
Is your swash level at 0, high and low collective position? Thats where I would start. Make sure you have 0 pitch when subtrim is checked, swash is level then make sure its level at its high and low using the servo corrections.
Adrian
Following the recommended trim, check if you got a nice hoover without stabilization, than your setup should be fine.
2nd make sure your swash is level and in a perfect horizontal position during power up and stays till FBL is initialized. On some Heli you have to tilt Heli a bit forward or backward by lowering or lifting and holding tail during initialization to get perfect horizontal SP position.
Rcpassa
Tomas, does this make sense? Btw, I don't use stabilization. I use the rescue feature.
I guess that the problem is somewhere in the servo settings. I recommend to check if the swashplate is perfectly horizontal in min., max. and center positions of the collective when you enter Servo Travel Correction menu.
