having trouble with 2.0
mb-1953
My pro wanted me to first download 1.3.2, which I didn't have. I downloaded the version that was posted on helifreak by Tomas. After the download the software said congratulations on downloading version 2.0. The pro will not connect and when I apply power the red light blinks once but that is it. Help please
Coco66
Use the Recovery mode:
1. Start the software and then press No when prompted to Demo mode.
2. Select the firmware in the Update tab and press the flash button (you should see Recovery mode label immediately).
3. Connect the battery to your model (with USB interface connected). Then you should see a new flashing progress.
You do it with software 2.0.0 and load firmware 2.0.0
You will have to set it up from scratch after done.
Please make sure that you have correct driver installed so it can't happen again. What is your operating system?
mb-1953
Windows 7 professional
mb-1953
I tried what coco suggested but there is no flashing, the screen does say recovery mode but nothing happens.?
mb-1953
I was able to first recover 1.3.2 and then 2.0. Looks like I am out of the woods. Thank you
I recommend to try recovery mode with 2.0.0 software. It might help you.
Also you can try to disconnect ELE/PIT/AIL cable that is in the unit.
