Version 2 rescue
agh321
Hi just downloaded version2 and re set my trex 700n in but what ever I do the rescue goes into negative pitch in normal and acro.
trying to adjust and can go from -8 to 0 deg but no + pitch
What have I missed
it looks like the basic setup was not done properly.
First from all please make sure that your sticks movement correspond to the Diagnostic tab, especially all the directions.
So when you move your collective pitch stick to the positive, you will see that the bar is positive as well.
Alyon187
Also make sure your servo connections are the same as what the swashplate shows. Unlike the previous version, servos 1 & 3 matter which slot they go into. That and that you select the correct swashplate orientation and set your servo reverses in your radio back to their default position. W 2.0 any reverses should be done in the software, not in your tx.
agh321
Alyon187 wrote:Also make sure your servo connections are the same as what the swashplate shows. Unlike the previous version, servos 1 & 3 matter which slot they go into. That and that you select the correct swashplate orientation and set your servo reverses in your radio back to their default position. W 2.0 any reverses should be done in the software, not in your tx.
Ok I'll have another go
I do remember reversing the pitch and elevator servos in my dx9 to get the right direction
Thanks for the help
You have to get correct direction in the Diagnostic tab first. Then you should reverse channels anymore.
This is different between older versions.
agh321
ZeXx86 wrote:You have to get correct direction in the Diagnostic tab first. Then you should reverse channels anymore.
Ok thanks
I'll re set it up again tomorrow
Ok all done and rescue is fine now
Thanks for the help
Apart from the swash servo direction it does seem to be very straight forward now
With the wizard doing most of the set up for you
