Spirit Pro Stopped Working
Posted: Sun 06. Mar 2016 18:39:51
My new Spirit Pro stopped working during setup
This is what happened. Connected the Spirit to PC and updated to version 2.0. Disconnected power and exited program per directions. Powered up the unit and the software and began the setup wizard. All went well until I got to the step to check servo directions. During this step I received a message that the connection was unstable. Check connections and reconnect. I double checked all connections which were good but continuously got the same error when attempts to reconnect were made. Therefore I powered down the unit and exited the software to start over.
When I applied power to the Spirit it does not initialize. The LED continuously blinks rapidly and would not connect to the software. After watching the unit for about two minutes during which the blinking of the LED slows down and then speeds back up the LED turns solid. At this time I was able to connect it to the software program. However, the unit doesn't respond to inputs. Specifically on the diagnostic page moving the sticks on the transmitter does nothing.
I've tried going back to factory setting and reinstalling the version 2.0 firmware and it still is not working. I don't believe there is an issue with software program or the firmware file because I had no problems updating one of my other Spirit's (non Pro's).
Any suggestions on correcting this problem would be greatly appreciated.
