Stability Mode and Gyro Gain.
dcjacks
In version 2.0 I have set Bank 2 for Stabilization Mode. Do I have to use a negative gyro gain like -45 to go into stabilization Mode when using this bank or will bank 2 run the Spirit in stability mode with out setting a negative gain.?
I am asking because when I set me Helicopter up and set bank 2 (The mode for stabilization) the gain is 45. When I hit my bail out switch which makes the gyro gain negative (-45) the Swatch plate jumps to the 60% level and cyclic has no control just like it does in Bank 0 where i have set Rescue mode. Is the negative gyro gain only used for Rescue on all functions (Normal Avro, Stabilization, Acro Stabilization, Scale Stabilization and Coaxial)? If not why does my swatch plate lock in at the 69% like rescue in Bank 2 when I go -45 gain?
Collier
Coco66
The negative gyro gain simply activates whatever Stabi mode is selected for the current bank.
Are you sure that your system does not also switch banks (back to 0) when you hit your Rescue button/switch? You can check it on the Diagnostic screen.
