Different Firmware Versions and Spirit.bin
W.W.
Just out of interest: When having multiple Spirits on different models with different firmware versions. How can one do the settings from the Jeti transmitters? Does the actual Spirit.bin work with all firmware versions? Or is it necessary to have all Spirits on the same firmware version?
best regards
Wolfgang
regards Wolfgang
You need corresponding Spirit.bin file for each firmware version. Unfortunately Jeti allows just one BIN file per device, so you will need install same version on each unit (or to change the file in some way).
W.W.
would it be possible to append the FW version at the device name like 'spirit201' for the device explorer, so that you can use corresponding bin-files for the Transmitter 'spirit201.bin' (Like the different Receiver types)?
regards Wolfgang
Yes, this could solve the problem.
We can do this for future updates.
