[SOLVED] V2.0.1 Update Problem
FrankFuss
When I run the V2.0.1 Spirit Settings executable, it thinks it is detecting my Spirit Pro for the first time by Spirit Settings 2.0. This Spirit Pro was already updated to V2.0.0. After I update the Spirit Pro to V2.0.1, I get the same Welcome window when I run the V2.0.1 Spirit Settings executable. I did not have any trouble running the V2.0.0 Spirit Settings executable before this update.
I did not have any trouble running the V2.0.1 Spirit Settings executable and updating two other standard Spirits, which were also already updated to V2.0.0.
Thank you for the info.
Actually this issue was in the 2.0.0 in some very rare cases and it was fixed there.
Please delete .spirit-wizard.cfg file from your Documents directory. Then you will see the message again, then it should be OK.
FrankFuss
Thanks. Deleting the .spirit-wizard.cfg file fixed the problem.
