KDS Chase tail vags
henrikbach
Hello.
I got my no. 2 spirit yesterday. The first one is on a Gaui X5 and that works fine, but my second is on my KDS 360 Chase. The cyclic is ok, but the tail has some slow vags. I has tryed to increase the tail gain to 70, and then go down to 40 in small steps. The vags are about the same. The tail servo is Sawox digi and there are absolutly no bindings. Some ideas..
Kind regards Henrik.
you will need probably ball miller, because very often linkages are too tight with KDS helicopters.
For rudder it has to move very smooth so you can't feel any counter-force.
Can you attach your settings please? (4DS file). I can check if all is OK there.
henrikbach
Thank you for quichk reply. It was as you say, the ball link on the servo horn. I would have changed the servo to a stronger, but now I will loosen the link so it will go smooth.
I will test fly it tomorrow, and write back.
Ps. You´r Spirits fly VERY great and the rescue is the reason why I can fly heli now :lol:
henrikbach
Now I have ball links and links on rudder arm to Aligns types. They are fine loose. The KDS links had a tiny bind.
Now the Chase is test flown on factory settings with gyrogain on 50%, and the tail is rock solid. No tail wag at all. :D Tomorow I shal at the field and fine tune it. We have nice spring here now.
Kind regards Henrik. Denmark.
Perfect, thank you for the report!
henrikbach
And thank YOU for super support, and super produckt.
