Governor gear ration - max value possible too low?
jbod
I am currently setting up my Oxy3 and want to use the spirit governor.
So following the manual:
"Gear Settings - Gear Ratio
Gear Ratio of the helicopter between the main wheel and pinion of the motor. For example: 120T main gear / 12T pinion = 10."
In my case: 140 main wheel and pinion 10 results in 14. My problem is now that the max value is: 12.7
Any advice how to fix this?
Thanks a lot for any help in advance,
Andreas
Coco66
jbod
Coco66 wrote:This thread has your answer...
http://spirit-system.com/phpBB3/viewtop ... &view=next
Thank you very much for this ultra fast answer. Seems like I need new glasses :) Didn't find this thread.
Coco66
I just remembered I read it and made a Google search.
Not sure I myself understood the idea about faking the sensing divider though ))))
