Tail kick and revo-mix at 10 (limit)
Posted: Thu 24. Mar 2016 18:47:44
by Joeri_Plees
Hello everyone I have setup my Oxy 3 Qube main and tail with the spirit fbl and I have a little tail kick and the p gain and revo-mix is at the limit
Pgain at the max before tail hunting
So what can I do now or what is the problem to much pitch maybe for a 3 blade?
Best regards Joeri
Verstuurd vanaf mijn SM-N910F met Tapatalk
Posted: Thu 24. Mar 2016 18:48:46
by jgiannakas
Increase your piro consistency. You shouldn't need any revo mix. I was having the same issue and just upped the piro consistency parameter and was all gone on my 450L
You'll probably need to drop the p gain a bit as well.
Re: Tail kick and revo-mix at 10 (limit)
Posted: Thu 24. Mar 2016 19:00:23
by Joeri_Plees
Ok thanks I try that and lower the revo-mix again then?
Posted: Thu 24. Mar 2016 19:53:19
by jgiannakas
Yeap you shouldn't need any revo mix
Posted: Fri 25. Mar 2016 18:29:31
by Joeri_Plees
jgiannakas wrote:Yeap you shouldn't need any revo mix
Thanks for the tip man that's works great! I only have tail wag now... And before not :/
Best regards Joeri
Posted: Fri 25. Mar 2016 18:33:10
by jgiannakas
Joeri_Plees wrote:jgiannakas wrote:Yeap you shouldn't need any revo mix
Best regards Joeri
Drop your tail gain. Also what is your rudder delay value? What pirouette consistency did you end up with?
Posted: Mon 04. Apr 2016 23:42:05
by Joeri_Plees
I go to the field tomorrow hopefully and test it with lower tail gain.. And let you now the value of the consistency
Posted: Tue 05. Apr 2016 8:02:03
by jgiannakas
Joeri_Plees wrote:I go to the field tomorrow hopefully and test it with lower tail gain.. And let you now the value of the consistency
Thanks! Ive noticed that now that I've setup my governor to hold rpm more aggressively I have a minor kick when doing pitch pumps. Running 175 piro consistency on my 450L. Possibly need to up even more on my side or add 1 or 2 points of revo mix. Will be trying it at the field next time as well
Posted: Tue 05. Apr 2016 8:43:52
by velocity90
You will always get a small kick with agressive govs. Tune it out with revo too much and other things become worse. Side tick tocs to name one.
