Stick priority
Posted: Sun 03. Apr 2016 8:53:15
by henrikbach
Is Stick priority doing the same with the flying feeling as expo in the RX ?
Kind regards Henrik
Re: Stick priority
Posted: Sun 03. Apr 2016 10:23:47
No, it is very different and should not be used instead of Expo.
Spirit unit does not use any expos internally, so you can set e.g. 25% in your TX.
Stick Deadband is just to match precision of your transmitter. Value of 10 should work fine with the most transmitters.
Re: Stick priority
Posted: Sun 03. Apr 2016 11:23:44
by henrikbach
Yes, I know what stick deadband does. But what exactly does STICK PRIORTY do ? The function is in the stability tab.
Re: Stick priority
Posted: Sun 03. Apr 2016 14:27:05
by bill rob
ZeXx86 wrote:No, it is very different and should not be used instead of Expo.
so is stick priority just deadband?
Re: Stick priority
Posted: Sun 03. Apr 2016 14:43:21
Sorry, my fault.
Stick Priority determine a degree to which you can control cyclic while the special mode is enabled.
When it is 0 you can't control it at all with your sticks (aileron/elevator).
So this will allow you to set how much you change direction.
Re: Stick priority
Posted: Sun 03. Apr 2016 15:00:20
by henrikbach
OK, that make sense. The value is 0 to 16.
Is 16 equal to 100 % stick priority and 8 equal to 50 % and vice versa ?
Re: Stick priority
Posted: Sun 03. Apr 2016 15:09:31
Yes, it is.
Re: Stick priority
Posted: Sun 03. Apr 2016 15:30:28
by henrikbach
OK. Thank you :D
Re: Stick priority
Posted: Sun 03. Apr 2016 15:50:30
by bill rob
Forums are great,instant fix or understanding :D
