Flysky i10
FOXBAT1
I'm battling to setup Spirit Pro with Flysky i10
Firstly what type of receiver is the 10 channel Flysky. PPM, PCM ?
if you are using receiver FS-IA10 then it will work with PWM connection type.
This connection is preconfigured in the default settings so you only have to use supplied cables and connect it together.
I recommend to find out which channel output of your receiver corresponds to which channel - then you will be able to connect it correctly.
You should find it either in your transmitter or manual of the system.
FOXBAT1
Hi
Yes I'm using i10 rx. I can't seem to get it right
The channels on the Spirit configuration software doesn't correspond to the channels on the i10.
Do I connect to receiver as per what is on the radio ?
Coco66
Just try. In the end, the only important thing is that when you move the Aileron, the swash tilts right and left. Who cares about channel names.
FOXBAT1: It is normal that channel numbers are not corresponding. Each manufacturer has a different enumeration.
Important is, that you will achieve correct movement in the diagnostic tab (including directions). Then all is OK.
I recommend to start with the Rudder channel first, then with Gyro channel. You can always try it in any point to verify if it is good.
But be carefull to not connect power supply directly or indirectly to the SYS or ELE/PIT/AIL ports.
