Spirit seems dead
eblang
Tried to update to 2.0 inadvertently selected the bin file insted of 4df file. My pc program was 1.2.3 at that time .
I loaded v2.0 to my pc. And now can see each the correct file when I press select .
It says plug in power after you hit Ok,
I do this and it just sits there.
My spirit doesn't look like the ones in the photos where you jump the two pins so I have not done this type of recovery yet . Not sure what my next step i .
Thanks Gene
first from all, it is necessary to install correct USB drivers, especially if you are on Mac.
Then, could you please tell me, if the version was really 1.2.X or 1.3.X?
If it was 1.3, then you should be able to see short flash of the Status LED. If so, then you can fix the unit easily without a dismounting.
But it is important to check this first.
Thank you very much.
